monster clutch
Old Dec 8, 2011 | 11:17 AM
98blueSScamaro's Avatar
Originally Posted by Checkmate
My stage III chatters so bad I can no longer DD my car, I was told to beat on it.
3 track visits launching on slicks and no changes. Sure it takes the abuse at the track but I like to DD my car and I can't do that anymore. So I'm trying to figure out what to replace it with.
I have had ever clutch you put in a t56 trans. And Monster has the best product out. All clutch chatter with the psi plate's it takes to hold good power and the compound of the clutch puck it takes to hold the power for a long time. i rather take a chatter then replacing a clutch once a year. and also a lot of the chatter fall's on the driver.
And if you just dumping the clutch off the line drag racing will not help with the clutch noise. a good fast slip will from about 6000 rpms
Old Dec 8, 2011 | 07:01 PM
Zmg00camaross's Avatar
Agreed, These are clutch that take abuse and can be DD but mite come with a sacrific a tad with chatter. Thats why I went with the 11inch and its great.
Old Dec 21, 2011 | 09:54 AM
Dayhoff35's Avatar
what flywheel are you guys running with your monster stage 3 clutches?
Old Dec 21, 2011 | 12:04 PM
SNLPerformance's Avatar
Most run the 28# unit, it really depends on the setup and how you drive/use it.
Give us a call, we'll go over it with you and get you into a Monster.
Old Dec 21, 2011 | 12:33 PM
Dayhoff35's Avatar
probably looking to order a little bit after christmas, but have decided for sure that i want to get the monster stage 3 and everythign else with it. It will mostly be a track and such car, not a dd.
Old Dec 21, 2011 | 07:23 PM
I would look at there 11 inch race clutch ^^^. I drive it on the street and alot of track passes and has been flawless.
Old Dec 22, 2011 | 06:39 AM
Crashz28's Avatar
I just got my monster stage 2 and tick master cylinder I cant wait to put it in im very pleased with the quality of everything looks top notch I just wish the master cylinder would have came with some stickers you know for the extra hp lol
Old Dec 22, 2011 | 07:27 AM
Dayhoff35's Avatar
dont think i need anything that agressive i might consider it though, thanks. In all honestly im gonan drive it when its nice out and go to the track a few times a year.
