What would cause this?
Old Dec 15, 2011 | 07:14 PM
the_merv's Avatar
Veteran: Air Force
I've never had an issue..whatever works I guess.
Old Dec 15, 2011 | 07:50 PM
Jeremy@RPMTransmissions's Avatar
Glad its working good for you. I just haven't personally ever seen it work out for anyone. It has been the root of a lot of problems.
Old Dec 15, 2011 | 07:56 PM
94Z28-MSTGKLR's Avatar
Should I put a new plug in the crank as well? Is it leaking or did I not post a picture you could tell in? I just don't want to do this again because I over looked something.
Old Dec 15, 2011 | 08:02 PM
No I wouldn't mess with the plug. It looks dry. Id just put it all back together with a new seal.
Old Dec 15, 2011 | 08:12 PM
the_merv's Avatar
Veteran: Air Force
Ya Chris replace the Rear Main since you are there..
Old Dec 15, 2011 | 08:15 PM
Will do. Call me later Ben.
Old Dec 15, 2011 | 08:40 PM
the_merv's Avatar
Veteran: Air Force
I'll drop a line in a bit..I was driving to Little Rock earlier in the traffic when you called..
