I'm lost
Old Feb 1, 2012 | 06:48 PM
mob_barley's Avatar
Default I'm lost
About 2 weeks ago I shifted hard and lost all clutch pedal, mabey had an inch of movement. I took my master cylinder out to do the drill mod, but it had already been done on the line. Now with everything back in the car I can get enough pressure to shift into all gears except 1st and reverse. The clutch pedal moves about 4in until I feel pressure. I have bled 2 bottles of fluid through it, but nothing has changed. I bench bled it really well too. I think its my master cylinder(4 months old) because the pressure will bleed off if you hold the pedal in too long. Nothing leaks fluid though. Stock clutch and slave I think. What do you guys think it is? I don't want to keep buying master cylinders.
