Clunky Shifting
While I have great confidence in its' power capacity, the trans does not shift any more efficiently than the Muncie I had previously. While the throw is shorter than the Muncie, unless you do it just right, the 2/3 shift is an accident waiting to happen.
More recently, Keisler came out with their RS version of this trans. Their claim is 'smooth shifts' (thought I already had this), & 'no more missed shifts'.
Here's my point...last year, I saw an article on the web for Liberty Transmissions, in which I gathered that by simply machining a guide plate, that these shift issues were made a thing of the past.
I realize that there are all kinds of plating, parts upgrades, etc, that can be done to a T5...will machining a guide plate by itself, contribute to accurate shifts?
Previously, I had been hesitant to modify the trans. It is now removed from the car, so if it will be modified, now is the time. Thanks.
The guide plate limits rail travel. Machining it adds travel to the rail. This can only increase the likelyhood of linkage concerns......don't machine the guideplate. If you have shifting concerns, be certain the clutch fully releases and your shifter does not have excessive play.
If one's intention is to go from 5 to 4 (top right >>down-left-down), it's quite easy to put it in 2, instead. Likewise, shifting from 2>3 can cause the shifter to bog in the middle.
The clutch & hydralics work just fine.
Although I've been driving the Keisler for just over a year, it hasn't been easy to get used to, and I wouldn't recommend one, other than for the power handling.
Check the plastic socket the shifter engages in the trans. It may well not even have one or the worn.
