preload/anti-shock ??
Old Mar 26, 2012 | 09:16 PM
LSOHOLIC's Avatar
Default preload/anti-shock ??
Anyone preloading the driveline/supen. with the brakes, while on the 2 step ?? It would also act as a roll control. Just barely/slightly letting the clutch engage for a split second to load the driveline ?? As to not "shock" or upset the rear ??
Thanks......My Lingenfelter Adjustable Launch Controller, RPM Limiter 2 Step & Timing Retard (LNC-003) allows for more functions. Seems I could run a line-lock simultaneously. And both would release when the 2 step disengaged.
