TICKMASTER PRE setting?
Old Mar 31, 2012 | 06:43 PM
rad23's Avatar
Default TICKMASTER PRE setting?
i cant seem to determin the minimum setting on the tick adj master. i see the bump stop and the switch the has the protruding grey buttonbut where do you set the lowest setting before bleeding the first time jjust at the tip of the grey button depressed or do you ingnore that button?????
Old Mar 31, 2012 | 07:19 PM
1BAD02WS6's Avatar
What grey button?
Old Mar 31, 2012 | 07:20 PM
rad23's Avatar
the switch when the clutch is up
Old Apr 2, 2012 | 08:38 PM
NVR_SPDS's Avatar
Thats the cruise control switch. Dont worry about the switches until AFTER you get it bled, and the pedal height set for your clutch. Youll be able to adjust the switch to where it needs to be.
I would set it roughly half - 3/4s of the way up to th brake pedal for bleeding. You wont be putting pressure on the clutch yet, since youll crack open the bleeder before you put the pedal all the way down. Bleed it well, and adjust it until the clutch doesnt drag at all, then adjust your switch.. It screws in and out, and can be put where you need it.
Were running a Tick/Monster Level 2 combo.
Old Apr 7, 2012 | 12:01 PM
rad23's Avatar
go it all working thanks though, ill look into fine tuning up later today
Old Apr 7, 2012 | 12:17 PM
rabbitsws6's Avatar
i just installed mine, it works great. bleeding was so easy.
Old Apr 13, 2012 | 08:55 AM
rad23's Avatar
tell me about it talk about should gone with it in the first place, ive read and read and read and still tryed to hold out. should have bought it in the first place
