Should I try Synchromesh
Old Apr 21, 2012 | 08:04 AM
AMS13's Avatar
Default Should I try Synchromesh
When I did my clutch (Monster stage 2) over the winter I filled the tranny with a basic dex III from Napa. The tranny does not shift to smooth at all, and when I semi get on the gas and shift, it will sometimes grind. The car has a Tick MC in it, along with a speed bleeder.... I am wondering if its worth the $45 to try the GM Synchromesh, or is there a cheaper better alternative?
Old Apr 21, 2012 | 09:43 AM
edge04's Avatar
I just swapped in the Penzoil Synchromesh, heard good things. Will be driving the car a lot today so will give feed back later
Old Apr 21, 2012 | 10:52 AM
MeentSS02's Avatar
Kleeborp the Moderator™
It won't hurt anything, so if you don't like it, you can just drain it and try something else.
Old Apr 21, 2012 | 11:03 AM
Choppers's Avatar
Had nothing but grinding issues. Changed the fluid to Penzoil Syncromesh and it shifts perfect and smooth now.
Old Apr 21, 2012 | 02:10 PM
bad67ls's Avatar
i use nothing but syncromesh in my richmond 5 speed. nothing else works lol.
Old Apr 21, 2012 | 09:03 PM
predatorz28's Avatar
Another happy synchromesh user here. I was running the mobil 1 stuff and it seems to slide into gear just a bit easier now, also less grinding.
Old Apr 21, 2012 | 10:05 PM
Ferocity02's Avatar
Whats the difference between synchromesh and normal ATF?
Old Apr 24, 2012 | 07:27 AM
Rare96LT1Formula's Avatar
Changed my trans mount and trans fluid to synchromesh and my car shifts like butter now. It was worth the money imo.
Old Apr 24, 2012 | 08:52 AM
Deviant LS1's Avatar
The only difference I noticed with straight syncromesh was that the cold start notchyness was gone.
Old Apr 24, 2012 | 01:29 PM
gmdoctor's Avatar
You guys using the friction modified?
Old Apr 25, 2012 | 08:44 PM
oldmano2z's Avatar
i' use gm syncromesh on a new build. don't know if i can say their name on here because they aren't a sponsor,but they build almost if not all the prostock trannys. had parts shot peened,cryo'ed and viperized with carbon fiber throughout and that was what was suggested to use and i have no problems. got 1k on trans now and changing it tomorow again to syncromesh. good stuff , not recomended for the paper rings, but good for carbon fiber
Old Apr 26, 2012 | 09:12 AM
All-In's Avatar
From: Just because the voices aren't real, doesn't mean they're not right!
I use 50/50 mix:
Amsoil ATF Dex III synthetic
Amsoil MTF Synchromesh synthetic
Anti-venom mod (.082" thick)
MGW shifter
Buttah!
Old Apr 26, 2012 | 08:40 PM
HoLLo's Avatar
I use only Pennzoil Synchromesh in my car, and in a recent GTO clutch install I did with a buddy. The fluid has always been nice and smooth for me.
Old Apr 27, 2012 | 01:27 AM
Exidous's Avatar
I'll be rebuilding my t-56 in the next few months with the gearbox stage 2 parts. The tranny has about 30k miles on it and I don't think it has even been apart. It is very notchy. I look forward to trying some new syncromesh fluids to see what works later on. I would love to have a smooth shifting tranny.
Old May 5, 2012 | 10:29 PM
AMS13's Avatar
Well I manned aup and did it, put synchromesh in it. The car shifts 1000 times better, well worth the upgrade!
Old May 5, 2012 | 11:23 PM
PAULZ98SS's Avatar
That's good it shifts better. Is your trans stock or rebuild?
Old Apr 21, 2013 | 04:22 PM
Exidous's Avatar
Update.
The trans had been apart. By someone that did NOT know what they were doing. Silicone everywhere inside. I had to replace:
Mainshaft
5/6 driven
5th (inc syncro assy)
6th (inc syncro assy)
Rev (inc syncro assy)
keys
pads
3/4 fork
a $50 washer that should never have to be replaced
Think that's about it.
I tried four fluids after the rebuild. All carbon blockers.
Stock III ATF: VERY notchy. Hard to get into first.
Dex VI ATF: A little less notchy but not where I wanted.
Syncomesh: Better still but it still didn't feel like a trans should. Notchy/no grinding.
Redline ATF: Best I have found so far. It's not 100% smooth but a drastic improvement over the other three.
Old Apr 21, 2013 | 05:31 PM
mikh338's Avatar
bg syncroshift here, awesome stuff
Old Aug 30, 2018 | 09:54 PM
TheeCamaroKid's Avatar
6 years later........Penzzoil or AC delco?
Old Sep 1, 2018 | 10:26 PM
LS1 pwrd NOVA's Avatar
So should you put syncromesh even if it feels ok?
