Clutch sticking 98 TA
Just trying to figure out where to start without hopefully paying a fortune to get this fixed. I've sucked the fluid out of the reservoir and refilled it probably 20 times now and it's still the same. Sometimes it wants to work correctly and then other times it sticks to the floor. Clutch pedal feels very soft too. I know this is common but just wanting opinions on where to start.
Clutch slave, Clutch master?
Clutch master has gone bad. Our master solves the common sticking clutch issue. We are currently out of stock on them but go ahead and put you order in, because you will be in line to get yours when we receive the shipment of parts to build more kits. Here is the link:
http://www.tickperformance.com/tick-...or-ls1-f-body/
I've been reading and gonna replace the slave too while I'm at it and it looks like the one for $65 at autozone is basically the same as a gm one. Planning on doing this and getting the Tick master since the master is the POS in these cars.
Sound good?
Sound good?
