Straight foward answer...
Old Mar 27, 2004 | 03:37 PM
99CamaroSS's Avatar
Default Straight foward answer...
I did a search and only found that a certain Ram clutch has a firmer pedal pressure than stock. I drove a 92 mustang before i got my 99 SS and the clutch i had in that mustang was close to the type that would make ur leg start getting tired at a red light. Now the problem is my SS clutch feels mushy to me b/c of the previous clutch i had. I dont like that crap. What i'm lookin for is a firm pedal pressure that isnt gonna kill me at a red light but is deffinatly gonna be more noticable pressure than the stock clutch. So my main question is, w/ mainly bolt-ons, what clutch can i get to get a firmer pedal pressure? Thanks
Old Mar 28, 2004 | 12:18 AM
wrencher's Avatar
wrencher
Well that wont get to out of hand like the $hit$tains do unless you get a dual disc, they will definatly increase petal effort.
Your leg shouldn't be getting tried at a stop light though.
It is definatly not good to keep the clutch depressed for the duration of a stop light.
Not only is it uncomfortable to do, it's also not good for your throwout bearing, & hydraulics, you tend to build up heat this way.
The optimumn thing is to have the clutch depressed for a minimal amount of time, to prevent undue wear.
Old Mar 28, 2004 | 05:29 PM
angst911's Avatar
remember, we use a hydraulic clutch system.. it's no where near the same as a big clutch in a mustang.... my spec 3i feels feather light to me... I love it
Old Mar 29, 2004 | 06:43 AM
distortion_69's Avatar
I had a friend struggle with a light pedal, and it ended up being his master cylinder. If you think its abnormally light thats something you might want to look into.
That being said, my Ram 402/980 has a heavier than stock feel. It isn't insane, but it is feels good. I enjoy a hard pedal because to me it makes me feel confident its gonna hold. Only 4 clutch dumps on this one thus far, but about 5k-10k street miles.
If you plan on doing boltons only, or cam.. possibly heads/cam, you won't have any problem with the 402/980 setup, and it doesn't chatter all that much either
Good Luck,
Josh
Old Mar 29, 2004 | 10:18 AM
Stick only's Avatar
RAM's diaphragm plate is 2800 pound clamp load - stock is 2200.
Old Mar 29, 2004 | 10:53 AM
99CamaroSS's Avatar
Good Luck,
Josh
Thats how i feel, "makes you feel confident that its gonna hold" and i just like the firmer feel in general. its not incredibly light...but my buddies M3 clutch is firmer and that pisses me off. I dont want some german car to have a firmer clutch than my american muscle car. The ram sounds good, did you have to change or update you Master cylinder or anything? And when u said doesnt chatter all that much, does that mean u didnt get through the break in period yet or is it gonna chatter a little for the life of the clutch? Thanks!
Old Mar 30, 2004 | 07:57 AM
I changed to the mcleod adjustable master, but you can use an 01-02 if you wish. I really would suggest an adjustable if your picky about your clutch. I have mine adjusted just the way I like it
The clutch chatters on hills and such, but its not very bad at all IMO. Expect at least a little chatter though for the life of the clutch. You will learn to drive around it though, as its not that much.
Old Apr 12, 2004 | 12:32 PM
boondiggys's Avatar
hey if you want to have it harder to press just take out the spring up top on the pedal that helps pull the pedal into the cylinder....you are sure to be stiffer than the m3
