is this normal
Old Mar 27, 2004 | 04:37 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default is this normal
just installed my new spec stage 3 today and i was reading somthing saying that you dont need to bleed the clutch because it has a quick disconnect so i did it and it works fine i didnt need to bleed it,is this normal,and the chattering is horrible i hope it goes away soon
Old Mar 27, 2004 | 04:44 PM
rushman's Avatar
From what I have been reading here the chattering can be bad at the begining. As far as bleeding, you don't need to do a full bleed, but if you have a mity vac it would hurt to fit it into the bottom of the resevoir and create a vacuum in the line, which will allow any little air bubbles to escape. Find buschman's instructions, I'm refering to step 3.
Old Mar 27, 2004 | 06:22 PM
lower et then u's Avatar
When u replaced the clutch did you replace the fly wheel or cut the fly wheel or did you just take the clutch out and put the new one in. Also you don't need to bleed the clutch but it is a good ider to do any way. it can't hurt
WOT Racing Team
Old Mar 27, 2004 | 08:01 PM
i put a new flywheel balanced with the clutch it was the kit that spec has
