tick speed bleeder question
Old May 17, 2012 | 09:27 PM
99camaro5.7's Avatar
Arrow tick speed bleeder question
Ok i just got my clutch/tick kit, sorry for the very stupid question but.. how exactly do i use the tick speed bleeder? I'm kinda new to this part of the car and I'm looking for all the help i can get.
Old May 17, 2012 | 09:45 PM
HoLLo's Avatar
When installing the slave cylinder with the transmission out, you will remove the stock bleeder valve on the slave cylinder and install the line in its place. Run the line wherever you want to. Some run it into the engine bay, I have mine run under the car, tucked with the fuel lines so gravity will help the bleed process. When you want to bleed it, you just BARELY crack the valve, enough to let the fluid out, and no air back in. Once the valve is open, you can just pump the pedal over and over, just keep watch on the fluid in the reservoir so it doesn't drop below the hole. Just make sure the valve isn't letting air back into the system. It might take a few tries to get the valve right.
Old May 17, 2012 | 09:53 PM
so this is all done with the slave out of the transmission? And then when you're all done you just put the stock bleeder valve back in?
Old May 17, 2012 | 09:56 PM
HoLLo's Avatar
The transmission has to come out in order to install it, but the slave doesn't necessarily have to come OFF, but I assume you're installing a new one. The stock bleeder valve is basically just a long brass nut. You will just toss it out, because the speed bleeder line goes in its place.
Old May 17, 2012 | 10:03 PM
Oh ok so the speed bleeder line will come out of the transmission when everything is all bolted back together right next to where the line comes in for the slave?
Old May 17, 2012 | 10:25 PM
HoLLo's Avatar
Yes, here is mine:
Old May 17, 2012 | 10:30 PM
that answers alot of questions, i have one last one though. How often do guys usually bleed their system? One time good or is there a schedule?
Old May 17, 2012 | 10:32 PM
HoLLo's Avatar
I say bleed it when the fluid starts to get dark. My fluid stays clear for a very long time, so I've only BLED it once when it was installed, but I have pulled out fluid in the reservoir and added some new clean fluid once. My buddy's GTO gets super dark within a month, so his is bled often.. If the fluid is staying clear for awhile, I wouldn't worry about bleeding it until it darkens.
Old May 18, 2012 | 09:03 AM
Ok I lied I have another question lol. So you said it can be bleed alone but could I have someone help me do it? Just like bleeding brakes right?
Old May 18, 2012 | 09:14 AM
HoLLo's Avatar
Yes, it could still be done with another person, but the point of the speed bleeder is to do it solo. Crack the valve so it doesn't let air back in, and pump away.
Old May 18, 2012 | 10:06 AM
I just don't see how it let's fluid out but not air in
Old May 18, 2012 | 10:12 AM
HoLLo's Avatar
Trust me. The valve has to be just barely cracked though.
Old May 18, 2012 | 10:38 AM
Sales@Tick's Avatar
He is right it is a check valve only allowing fluid and air to travel one way. To be 100% certain you arent sucking anything back in you can crack the bleeder valve and stick it down in a cup of fluid too.
Old May 18, 2012 | 11:09 AM
ramairetransam's Avatar
turn the bleeder 1/4 to 1/2 turn.
Old May 18, 2012 | 02:41 PM
not really related to the hydraulics but i also got the 3 skims with this kit. Will i need them? And if so how do i know which one I'll need?
Old May 18, 2012 | 03:12 PM
sorry not skims lol. shims*
Old Jun 26, 2012 | 12:01 PM
02Z28LS1's Avatar
hey guys, just had a question about this bleeder....i see how it's installed, but the hole that it's routed through, is that already there, or is there any cutting involved?
Old Jun 26, 2012 | 10:28 PM
2001AntiVenom's Avatar
It's already there. No cutting required
