New clutch
Old May 22, 2012 | 07:35 PM
denscor's Avatar
Default New clutch
I getting my new build almost complete,but need a different clutch.I have a spec 3 plus in the car now but I want something different.More driver friendly.Took the car to the Rod Run in TN and wore my left leg out!
New build
436 RHS block
TSP rotationing Assemble
-.22 Wiesco Pistons
Mast LS7 Heads
lsx ls7 ported intake
Around 20 psi of boost
I like the Centerforce DYAD but have not heard any reviews on it. What other clutches are out there equal or better than it?
Old May 23, 2012 | 03:44 PM
SPEC-01's Avatar
I'm interested in the details of your set-up. The 3+ is not typically stiff to the point of causing difficulty in usage. When and where was the clutch purchased? Are you running an aftermarket master? Let me know as I am interested in helping assess this. Thanks,
Old May 23, 2012 | 04:06 PM
SNLPerformance's Avatar
Give me a call if Jeremy at Spec can't take care of you.
Old May 24, 2012 | 01:39 PM
denscor's Avatar
The old setup was a
LS7 built by TSP
Eagle Crank Stroker crank
Eagle Rods
F1a Blower
Flip drive
A and A 8 rib pulleys stepup
2 inch primary headers
LG 3 inch exhaust all the way back
Redone rear end
Stock flywheel
stock master
It was bought at WS6 store and installed by Tach it up Motorsports.
Old May 24, 2012 | 02:58 PM
SPEC-01's Avatar
When was this bought?
Old May 24, 2012 | 03:03 PM
denscor's Avatar
in 2008 but would guess milage on the clutch is around 1200 miles.Its in my 2001 Corvette.
Old May 25, 2012 | 11:04 AM
SPEC-01's Avatar
I would be happy to check the effort of the unit for you if you like. Give me a call and we can discuss the details.
