quick ?
Old Mar 30, 2004 | 11:37 AM
spdrsr1's Avatar
Default quick ?
so i have bleed about 2 bottles of fluid through the master cylinder, how much does it take to bleed this thing....i can almost get it into 3rd gear, does this mean i have to keep going..
Old Mar 31, 2004 | 12:17 AM
Onyx Z's Avatar
What kind of MC?
Old Mar 31, 2004 | 10:26 AM
spdrsr1's Avatar
its a 99Z, with 02 master/slave
Old Apr 1, 2004 | 04:16 PM
spdrsr1's Avatar
so does anyone know if 2 bottles should be enough for this thing to get into gear?
Old Apr 1, 2004 | 04:24 PM
rushman's Avatar
its not necessarily how many bottles you put through. If you have a mity vac, try buschman's guide, step 3 to get any small amounts of air out. If you aren't seeing any bubbles at all and you still can't get into gear, something else might be wrong.
Old Apr 1, 2004 | 10:31 PM
spdrsr1's Avatar
i bought a mity vac but when i fill the cup, and pump it, it doesnt build up pressure..
Old Apr 2, 2004 | 12:21 AM
spdrsr1's Avatar
okay so i can finally build pressure into the mity vac...i was pumping the clutch like it says in bushman's last step for about an hour... i turn the car on and i cant even slam any of the gears in with the clutch down... any suggestions as to why my gear wont go in
