T56 help please.
Old Jun 5, 2012 | 04:22 PM
dmaxguy2008's Avatar
Default T56 help please.
just got a t56 magnum. it is the higher ratio one...but its out of a 98 cobra...is there anyway I can make this work with my sbc. need help with bell housing clutch release bearing ect...really wanna make this work. was thinking I was going to have to change my input shaft and/or the front cover plate on the trans. help or advice would be awesome! please tell me I'm.not the only one ever to attempt this!!! also I believe the tremec number is tuet-3451??
Old Jun 5, 2012 | 05:27 PM
no one
Old Jun 5, 2012 | 06:08 PM
85MikeTPI's Avatar
1998 cobra? Would have to be installed by the PO since the magnum is about 10 years newer.. Post pics and specs on it if you want help in 1hr after you post...
Old Jun 5, 2012 | 06:57 PM
thesource's Avatar
It's a ford magnum with a 7 oclock fork position. You will need to swap the mid plate and input shaft if going with a internal slave cylinder like a ls1. McLeod also offers a hydraulic kit that will work with your current mid plate.
