Not synchro?
Old Jun 22, 2012 | 06:10 AM
Kev SS's Avatar
Default Not synchro?
My trans sometimes makes a strange noise when going into fifth. It doesn't try to fight back or pop the stick back out just when I release the clutch makes a catching sound like the gears caught. This is only if I slow shift. If I shift it real fast and pretty rough it doesn't make any sound, and goes fine.
I also put a new master cylinder on the car and I sitll have a sticking clutch pedal at high rpms
Old Jun 22, 2012 | 09:27 AM
chrysler kid's Avatar
Did you do the drill mod to the clutch line from the master cylinder?
Sticking pedal is a pretty common issue, some times it can be solved with bleeding the slave, others with the drill mod.
When in doubt spend some down time using the search function an it should help you narrow down your issues with solutions people have had with the same problem
Old Jun 23, 2012 | 12:54 PM
Kev SS's Avatar
I done the drill mod. I know that the clutch sticking problems is prolly gonna be my master cylinder now. I was really wondering what people thought about the first problem I talked about.
