Clutch bleeding help
Opinions?
Thanks guys!
You need a vac pump mighty vac(most part stores rent these)
Goto a local hardware store and pick up a rubber stopper the same diameter as the opening in your resivoir.
Drill a hole in the stopper and insert fitting from vac pump in stopper. Pump -5 release -10 then release. Repeat process twice and then you should be good to go.
I just haven't felt like messing with it lately I've been chasing down some mystery tick in my engine to no avail and have found it yet
