Faceplating True Cost?
Here's my problem below if anyone can chime in to see if I'm on the right path.
My car have recently gotten to the point where I can't powershift into 3rd or 4th @ WOT.
I can still PS or Shift quickly just riding around town but the consistency of doing it back to back during pulls is nearly impossible @ the moment.
Will faceplating fix this problem "which I think it's the synchros" or is it in the hydraulic side?
BTW I am running a Tick MC.
Tick performance has a face plate option on their site.
And fwiw if it just locks you out of gear its most likely hydraulics but if you hear a grinding going into gear then synchros. If it is hydraulics try the tick m/c if that fails it maybe the clutch
New clutch, Tick & Slave. It's not a grind. It's seems like the shifter get stuck in between 3rd&5th. Kind of hard to explain. And 4th just don't engage in time. Don't get me wrong. I can still shift pretty quick till where the power never fall off but PowerShifting is out the door.
Sweiser
I have a high tolerance level & have listened to some of the cars on Youtube which don't sound toooo bad. Like I said. She's not a DD but when I do drive it. I DRIVE IT!!
Thanks for the inputs. Gonna think about it a little while longer but as of right now, i'm still leaning towards the faceplating.
I just spent $4,500 having RPM rebuild the T56, add GForce 9310 Dog cut gears and liberty faceplating/micropolishing it. Another transmission went in with mine for faceplating and rebuild only and I think it was around 3 grand. The work was flawless, the concept and design of the work done was incredible. RPM had an article in GMHTP recently about the T56 Magnum. Were I to have the half of a year of my life back it took them to finish the damned build I would have considered going for the T56 Magnum, mainly because they wouldn't have to depend on Liberty for the micropolishing. That is total cost guys less shipping but not including Quick time Bellhousing and a twin or triple disk clutch capable of holding the horsepower. So you are talking another 1200-2000 dollars outside of the immediate transmission work unless you already have that stuff. Then again why would you rebuild a transmission and put a used clutch in it? So tally $6,000-$6,500 and 6 months downtime, pretty much an entire season, for the TCO.
Since it took six months to do the work I decided I didn't want to risk another wasted season waiting on fixes to any problems so we took the tranny apart and I bought a Stage 5 TH400 from FTI. Best decision I ever made; rated at the same RWHP, and about a thousand dollars cheaper.
We made a flower pot out of the T56 case and sold the 9310 internals for scrap.
studderin-yea for the price & driveablity without noticing any improvement would be pointless.
LFSADRG-2500 without shipping. WOW
