Clutch issue
Old Sep 21, 2012 | 09:45 PM
Ls1AR's Avatar
Default Clutch issue
The problem is that the clutch will not disengage. I have a 240sx with an ls1 swap. I have replaced the whole clutch assembly with a monster 11in ceramic race and 28lb fly wheel, brand new gm bolts for both. I have a brand new tilton 75 series 7/8 master cylinder and a brand new slave from autozone. Monster says that they do not require a shim but as of right now I have tick performance .100 shim installed. Pedal feels firm and like a solid pedal so I don't believe its a bleed issue.
When the car is sitting still with the motor on and clutch fully depressed, when I try to put the car in gear, the car starts moving forward and will not go into gear. Does anyone have any ideas what is causing this.
Old Sep 22, 2012 | 09:13 PM
Ls1AR's Avatar
Issue was monster sent me the wrong clutch disk, it was too large for the pressure plate.
