bent alignment pin
Old Oct 25, 2012 | 10:35 AM
nickb123's Avatar
Default bent alignment pin
I am currently installing my stage 1 monster clutch. When i removed the transmission i removed it with the bell housing attached. When i got it out i unbolted the bell housing from transmission but it had a crack on the part that is between the slave cylinder posts. I tried to get it off with out breaking it but could not. So after i broke that piece it was still stuck to the transmission on the alignment pin. So with out thinking i hit the back of the broken piece with a hammer (it stuck out past the transmission) and i just noticed a week later it bent the pin. What should i do? Do i need both pins of would 1 be ok? Im afraid if i hit it the other way it might crack the transmission. Also i jb welded the bell housing piece back on and it seems to align with the bolt hole.
Old Oct 26, 2012 | 06:44 AM
nickb123's Avatar
Anybody have some thoughts?
Old Oct 27, 2012 | 08:31 AM
nickb123's Avatar
Im sure someone has had this problem before or has some input on it.. This is the only thing keeping my car off the road! Help...
