Need help deciding which T56
You have a core you can have D&D or another qualified company modify with what is often refered to as a "Viper" T56. The Vipers have bigger output shafts (maybe input to, would have to check) which require the tail shaft to be machine out on a T56. Along with some other upgrades. I know D&D does this.
You could sell your T56 core and get the Magnum. Compare the costs of buying a Magnum vs the cost to modify a T56 and also selling the core and using that $ towards buying the Magnum.
