Need help solving...
Old Nov 26, 2012 | 09:09 PM
99 DUKE'Z 28's Avatar
Default Need help solving...
My m6 is stuck in first gear. I can "shift" into each gear including reverse and neutral but it's still just in 1st gear. Clutch works fine. I have no idea. Checked today, is not shifter or the "rod" pin? Had someone check for me. They believe it's something minor but internal. Any help is appreciated!
Duke
Old Nov 27, 2012 | 02:51 PM
T56pro's Avatar
Does the car try to stall out when you shift it into another gear and let the clutch out? You could have busted something in the interlocking mechanism.
Old Nov 27, 2012 | 03:24 PM
Clutch works normal, it's just stuck in first. I have to have clutch pressed in at a stop or car would stall out due to not being able to put it in neutral.
