Clutch Question
Old Dec 20, 2012 | 01:55 PM
MeMz's Avatar
Default Clutch Question
Still searching the forums for this information. But my question is, I have an 02 SS with a 76mm front mount turbo.
Makes close to 500 hp to the wheels. I'm looking at the Monster Stage 2 or stage 3 clutch. The clutch that is in my car is 11" or 12" in stock form? I'm going to daily drive this car, so which stage would better suite my needs.
Old Dec 20, 2012 | 02:31 PM
SNLPerformance's Avatar
I would go with our Level 3 12" unit. It will give you some extra room to "turn up the boost"
Old Dec 20, 2012 | 04:48 PM
MeMz's Avatar
What's entailed with the installation of a 12" unit? Does the kit come with everything you need to install it or is there extra components needed.
Old Dec 20, 2012 | 07:36 PM
JaYZeig's Avatar
i can vouch for the level 3 monster clutch setup, i have the same setup
also with their 18lb flywheel and its been holding its own at 640rwhp 670tq.
the kit will come with everyhting you need for the install, and i would suggest
buying a new flywheel.
Old Dec 20, 2012 | 08:58 PM
MeMz's Avatar
What brand flywheel? Whats the difference between the 11" and the 12"?
Old Dec 22, 2012 | 11:53 AM
We are a clutch company, we don't buy a flywheel here and a pressure plate there... etc. ALL of the components in our clutch packages are Monster Clutch components.
The premium package will include the following -
  • 12" H.D. Pressure Plate
  • 12" Level 3 Disc
  • 28lbs Billet Steel Flywheel - or optional 18lbs unit
  • Release Bearing
  • Pilot Bearing
  • Alignment Tool
  • Brand New GM Slave
  • All parts balanced
The only thing I recommend besides what is above is a set of bolts ($24.99) and one of our 36" remote bleeders ($29.99). If you're still running the factory master and it's a high mileage unit get a Tick while you're in there.
Let me know if you have any other questions.
Old Dec 23, 2012 | 03:30 PM
Blackpanther99's Avatar
I heard and read about Monster Clutches, they are a great clutch.
Old Dec 23, 2012 | 06:47 PM
SILVERT's Avatar
Monster stage 3 here as well. I have the 28lb flywheel to get my heavy car moving. No complaints at all.
Old Dec 24, 2012 | 11:01 AM
JaYZeig's Avatar
i highly recommend the remote bleeder...i didnt get one when did my whole install..
and well yea....its a bitch without it....youll thank me later.
