Speedometer Cable
Old Apr 16, 2004 | 05:38 PM
taciam's Avatar
Default Speedometer Cable
I'm pulling my LS1 and manual trans from a 98 camaro and am stuck on how to disconnet the speedometer cable from the trans. Please help if anyone knows how?
Old Apr 16, 2004 | 07:11 PM
Camaroholic's Avatar
There is no speedo cable. The Vehicle Speed Sensor is an electrical connector on the rear driver's side of the trans.
Perhaps you mean the hydraulic clutch line? It connects on the driver's side front of the trans, between the bellhousing and the tranny.
You need to push in on the line slightly, and while it's pushed in, push the plastic ring in with a pair of crossed screwdrivers (it's a bit tricky). When you get the plastic ring pushed in a little, pull out on the line, and it pops right out. Most of the time.
