starter depth
Just pulled the flywheel off, no spacer behind it. If all starters for LS are the same, then how could this flywheel work with any year car with the LS unless in fact there are different depth starters???
How come I'm the only one answering here? I checked auto wreckers and they are 10mm from block to ring gear. Mine is 14mm. So sticks out 4mm farther. So it must be either the Spec twin flywheel or the Lunati forged 4" stroker crankshaft.
Does that ring any bells???
