Drill Mod On Slave
Old May 13, 2004 | 06:00 AM
thxone's Avatar
I think there maybe some confusion regarding the roll pin. I think we are talking about the roll pin holding the quick disconnect fitting to the slave assembly. See the attached picture of a "288" slave
Old May 14, 2004 | 10:06 AM
70T/A400's Avatar
Has anyone on this board performed this modification? Sounds like it complements the drill modification on the master.
Old May 14, 2004 | 06:14 PM
WS6FirebirdTA00's Avatar
i looked on mine and i stuck the drill bit in and it went in all the way without a problem. so i wonder if its jsut a vette thing. cause i looked at this after i did my drill mod on my old slave.
Old May 16, 2004 | 08:32 PM
5 Liter Eater's Avatar
Just got my slave in the mail from Fred Beans and immediately removed the roll pin and the restriction is right where the hose mates up with the slave body just past the roll pin. Drilled it out to 1/8". The pic below is a vette slave. Looks like the only difference between it and the F-Body slave is the hose rather than a short hard line to the quick disconnect. I have heard that there is another restriction at the 90 degree bend in the vette slave hose but have not confirmed it. In any case I would imagine the F-Body slave has the restriction at the end of the hard line where it meets the slave body like my vette slave did and therefore drilling out the CMC hose restrictor would do next to nothing without also removing this restriction. Can an F-Body guy confirm this? It would be a shame if everyone who thought they had done the drill mod had only done half the job.
Old May 16, 2004 | 09:50 PM
the fbody slave looks nothing like that. only the hard line. ill try and get a pic. there is no restriction what so ever in mine that i could find. the drill bit went right in the whole way. i take it its jsut a vette thing
Old May 17, 2004 | 05:18 PM
That may be. There are actually three restrictions in the vette's hydraulic system and two require some major work to get to!
Old May 17, 2004 | 05:46 PM
Reboot's Avatar
Actually, McLeod makes a 4AN line with a quick connect fitting that runs from the master to the quick connect on the slave. This will get rid of all your restrictions once the slave drill mod is done. It's a pretty sweet setup.
Old May 20, 2004 | 09:55 PM
Reboot's Avatar
Default ***Update***
I did the drill mod on the slave and ran a 4AN line directly from the master. The car shifts like a dream at any rpm. However, I think it needs a little restriction to engage a bit slower. This thing is either off or on without any middle ground. I am going to try running the stock line from the master just for **** and giggles, to see if there's any difference in the engagement. My slave line was drilled from 1/16th to 9/64th's.
BTW- this is with a new Exedy Twin Disk
Old May 20, 2004 | 11:25 PM
WMSuperSport's Avatar
Those pin connections you refer to are banjo joints. There are a few people who are try to get convert those connections to AN fittings and thicker lines but no one will post results if theyve completed it. Id like to try it myself. Moves more fluid...
Old May 22, 2004 | 05:23 PM
Wow! This is the first time I have heard of someone not liking the drill mod. How much is the McLeod 4 AN line BTW?
Old Jul 4, 2004 | 07:36 PM
mattz06's Avatar
doing this now, vettes are NOT the same as f body cars!
our restriction is at the slave
Old Aug 15, 2004 | 10:34 PM
  #32
DanZ28's Avatar
Thought I would resurface this thread. I just bought a brand new 01/02 F-body Slave. I pulled the retaining pin and quick dissconnect assembly. I then installed a 1/8" drill bit by hand in the Slave, and it slid in no problem, the hole was actually bigger than the bit was. Same goes for the quick dissconnect shaft, 1/8" bit was smaller than the shaft hole size. So on an F-body, the only restriction I see, is at the braided line on the master. Vette's must be different..
Dan
Old Aug 16, 2004 | 12:44 PM
  #33
You are correct Dan. There are three resrictions in the vette hydraulic line and the one at the slave is one of them. This restriction in the slave is not present on the F-Body slaves.
Old Jan 15, 2011 | 08:11 AM
  #34
FLA.SHEE's Avatar
back from the dead for you vette guys
Old Oct 8, 2012 | 12:14 PM
  #35
Cal's Avatar
Cal
Thanks, was just trying to figure this out for my 2001 Vette!
So what are the three places that need to be drilled? The slave and where else? The master doesn't look like it would be drillable, but I could be wrong.
