Clutch Disc Replacement
Mine is getting close to be worn out.
The plate, disc & flywheel should all be balanced together before install anyway.
An LS PP should be neutral balance in any case and the weighted FW being turned a bit won't put it out of whack on most apps.
Let us know how balancing the disc goes for you though.
