A4 to M6 conversion: 2000 T/A ...???
1.) Stage 2 T56 from a performance shop. I believe the slave & pilot bearing are included. (NEW)
2.) T-56 bellhousing (used)
3.) Monster Stage 2 Clutch & 18lb flywheel. (NEW)
4.) Tick Master Cylinder (used)
5.) Manual Pedal Assembly (used)
6.) 98-02 manual crossmember (used)
7.) trans poly mount (used)
8.) shifter insulator (used)
9.) manual center console w/ boot. (used)
10.) Hurst shifter w/ stick (used)
11.) Torque arm mount w/ poly bushing & bolts.
12.) 6 Trans to bellhousing bolts.. (I think I need 2 more) (NEW)
13.) reverse lockout solenoid
Need:
-I still need to buy a clutch reservoir if the Tick doesn't come with one.
-Shifter ball
-fluids.
-PCM reflash (Already got a friend to do it for me when the time comes)
-harness rewiring (on day of)
Have I forgotten anything?
Your list looks correct to me because my list says the exact same thing. Lol
My only difference is I'm going with a stage 3 monster and I'm putting a s60 with 4.10s behind it.
Oh, ... and connectors for the reverse lockout & reverse lights.
