torque specs
Old Apr 24, 2004 | 07:54 AM
ta12sec's Avatar
Default torque specs
Bout to install my spec and I have no torque specs, ANY BODY HAVE THEM FOR THE FLYWHEEL ---> CRANK and pressure plate to flywheel.
TIA
Old Apr 24, 2004 | 08:24 AM
Scooter70's Avatar
There is a sequence for them. For the flywheel, go 15ft-lbs, then 37ft-lbs, then finally 74ft-lbs. Tightnen in a criss-cross pattern and use loc-tite. For the pressure plate, go 35, 45, 50ft-lbs, criss-cross with loc-tite. (These numbers came from the Cartek clutch install document on ls2.com that I used to install my Z06 clutch.)
-Matt
Old Apr 24, 2004 | 08:35 AM
ta12sec's Avatar
Thanks
