Why can I shift into reverse while moving forward?
Old May 5, 2013 | 03:16 PM
1bdbrd's Avatar
Default Why can I shift into reverse while moving forward?
I have noticed a couple times that I can shift from 4th to reverse with no reverse lockout stopping me. Both times I have caught it before letting the clutch out so no harm. And both times as soon as I stopped at a light and took off again it started working just fine again.
Is this an issue anyone has had before?
Old May 5, 2013 | 09:21 PM
JaYZeig's Avatar
id check power/ground to the reverse lockout connector first,
then more than likely id say you've got a bad lockout solenoid.
Old May 6, 2013 | 07:39 AM
1bdbrd's Avatar
I'm just hoping its not wire related because it doesn't happen every time I drive the car. And as far as I know when it does happen its only for the first few stops. I don't think it ever happens after I've already been driving a while.
