problems fitting quicktime bellhousing to 6.0!!! help!
i have model : rm-8020
The problem i am running into is when i fit the trans up, the BH flange is wide enough at the top that it hits the bolts for the back cover. I had seen that some say the 6.0 BH flange is futher foward, meaning the back cover would stick out further past the flange? i had the same problem trying to fit the sfi plate behind the flywheel.the back cover sticks out further.
thanks in advance
