tranny question
Old Jun 2, 2013 | 11:04 PM
1981fbody's Avatar
Default tranny question
are the 6 speeds in firebirds from 1998 to 2002 the same as the ones in the gto from 2004-2006?
Old Jun 2, 2013 | 11:15 PM
1981fbody's Avatar
put another way. Could they both work in a swap into an 79 trans am.
Old Jun 3, 2013 | 06:48 AM
ptsmatt's Avatar
Depends on the engine type. If your using an LS it will be pretty straight toward if using a lt or small block then you will have to change or modify the midplate. The offset lever will have to be changed for the f body shifter use on the gto. The gto is an LS t56 wither different internals and a. 2.97 first gear ratio and a junk extended shifter assy
