change trans fuild (manual)
Old Jun 14, 2013 | 09:53 PM
stroker87's Avatar
Default change trans fuild (manual)
well changed all the fluids in my car clutch, brake, engine & diff now thinking of changing the trans fluid?
any one point me in a how to post or video? and what should be used?
2k z28 m6
thanks
Old Jun 15, 2013 | 04:26 PM
3rdCoastPowerSports's Avatar
ATF fluid,,, dex III/4
I prefer and use Mobil 1 ATF. Fill and spill
Old Jun 16, 2013 | 10:41 PM
stroker87's Avatar
really 151 views no one willing to take time out to help
so much for friendly............
God bless
Old Jun 17, 2013 | 01:03 AM
67goatman455's Avatar
he gave you your answer. crawl under your car. there is a sticker saying to use dextron III and there are two plugs clearly marked drain and fill.
Old Jun 17, 2013 | 07:13 AM
niscur29's Avatar
I used a cheap fluid pump from Walmart to get the fluid throw the fill hole. Not much too it really.
Old Jun 17, 2013 | 04:04 PM
stroker87's Avatar
ATF in a manual trans?
Old Jun 17, 2013 | 05:33 PM
nitroheadz28's Avatar
Are you really this lazy?
http://www.bfranker.badz28.com/fbody/lubeoil.htm
Scroll to the bottom, everything you need is there.
Old Jun 17, 2013 | 07:33 PM
stroker87's Avatar
no i searched but couldn't come up with any thing in detail
thank you!
Old Jun 18, 2013 | 07:52 AM
Rare96LT1Formula's Avatar
I bought a siphon pump from harbor freight for $6, and it made filling the trans MUCH easier.
http://www.harborfreight.com/fluid-s...ump-93290.html
Old Jun 18, 2013 | 10:02 AM
I just swapped my trans (not ready to go yet because my slave took a crap), but I was planning on leaving the fill plug out and filling through the shifter until it overflows down there- easier for me since I have the shifter off anyway.
