bleeding the clutch?? how?
Old Apr 27, 2004 | 02:32 PM
pwrtrip75's Avatar
Default bleeding the clutch?? how?
is there any easy way to do it? i havnt even attempted it yet, do you need 2 people?
thanx.
Old Apr 27, 2004 | 03:06 PM
Camaroholic's Avatar
Need 2 people? Naah. Just drill a 3/8" hole in the floorboard right above the bleeder valve (just an ooch towards the driver from the gas pedal). Slip a socket extension through there, and you can pump / crack / tighten / release all day long by yourself. Fold the carpet back over the hole, nobody but you will know it's there. Makes bleeding a snap, and you don't have your wife complaining about having to pump the pedal. Been there, done that.
Old Apr 27, 2004 | 06:19 PM
pwrtrip75's Avatar
not only will the hole aid in bleeding the clutch, it will also lighten up the car some. maybe i should drill a few holes? i dont have anyone here at the moment, ive used a 2x4 before on brakes. suppose i'll have to do that. push the pedal in, wedge a board in against the seat to hold it. lol, whatever works.
Old Apr 27, 2004 | 09:07 PM
Yep, some of us will go to extreme measures for weight reduction.
I tried the board trick, never could get it to work well for me. Drilling the hole allowed me to bleed the clutch quickly (and without the up/down/crawl/up/down/pump/up/down/crawl activity... I'm too old for that ).
Old Apr 28, 2004 | 06:20 PM
pwrtrip75's Avatar
i did it w/ a board, the power seat worked awsome.
