Monster level 2/tick installed
If you see any fingers that are lower or higher than the rest of them then you have found your problem. You shouldn't have any vibration at all in that combo.
The reality is the vibration you're feeling is in the bearing/slave assembly. The bearing doesn't spin on the face of the pressure plate, the pressure keeps that from happening so the only thing rotating is the release bearing itself.
When you depressed the clutch did the vibrations go away? Give us a call today and we'll get this figured out.
