2012 camaro t6 ????
Old Jul 4, 2013 | 12:23 PM
z06 hellcat's Avatar
Default 2012 camaro t6 ????
How can attach a 2012 t6 trans to a 69 camaro rearend dont how to make the connection at the trans with an older yolk style driveshaft
Old Jul 4, 2013 | 01:44 PM
Jeremy@RPMTransmissions's Avatar
You will need a custom driveshaft with the 3 bolt flange at the trans, a slip joint in the middle (since I assume you have a solid rear axle) and a U-joint in the rear.
