Hard to get into gear
Old Jul 11, 2013 | 01:58 PM
fletchman 96's Avatar
Default Hard to get into gear
I hope that someone can help with this, as I feel that I need to remove the transmission, and I want another opinion before I go that route. To start with, my clutch pedal was sticking, so replaced the clutch master cylinder in hopes that would solve the problem. Keep in mind the transmission would shift and go into all gears without grinding and what not, but would sometimes pop out of fourth gear. So anyway after the new master cylinder install. It has become very difficult, almost impossible to get into any gear and when I try to it grinds horrible. I have not tried to bleed it again, as I thought I did pretty well as the clutch pedal is much better. is it a bad slave, or something broke/bent in the trans? any input is appreciated. Thanks
Old Jul 11, 2013 | 03:39 PM
2000ultraZ1911's Avatar
Sounds like a slave. I don't know about it popping outta gear tho...
Old Jul 11, 2013 | 05:45 PM
SNLPerformance's Avatar
I'm confused have you bled it after installing the new master? Also confused at how the pedal feels good, but slave could be bad? Is it leaking anything?
