Is this normal?
Old May 3, 2004 | 11:21 AM
2000Z28M6's Avatar
Default Is this normal?
I just finished the drill mod. Major Pain In Da ******* ***!@ Anyway I bled the system before putting into the tranny. I felt I bled it enough, when bleeding it the pressure of the oil coming out with the line open was continous and it didnt show any air in between pumps. Now that it assembled the clutch feels like it engages a little to low. The first few pumps after being back into the tranny it kept getting stuck in the bottom position, so I pumped it till pressure was restored, could that of caused some air in the system? Havent had a problem goin into any gear though.
Old May 3, 2004 | 11:30 AM
rushman's Avatar
That sounds like a little air in there. Hit it with a mity vac from the top (buschman's guide) and you should be all set. Even though there is that quick disconnect for the line, I'm sure a little air gets in there. The master is a pain to get all of the air out.
Old May 3, 2004 | 12:13 PM
2000Z28M6's Avatar
So what if I did get air into the system? Do I just remove the quick disconnect fitting and keep bleeding and flushing it ?
Old May 3, 2004 | 07:58 PM
SMOKIN01TA's Avatar
no, you use the bleeder screw above the quick connect to bleed it like you do breaks. kinda need 2 people for this.
also mine did the same thing after the clutch install, now its fine.
Old May 3, 2004 | 11:57 PM
2000Z28M6's Avatar
I added a little more fluid since it was lacking some. I'll look for it but I think its doin fine for now. Thanks
