where to get input shaft?
Old May 3, 2004 | 01:28 PM
onyxxtreme's Avatar
Default where to get input shaft?
who sells replacement t-56 input shafts? I dont wanna know what GM will charge me
also anything on the web that shows how to replace them?
Old May 3, 2004 | 02:52 PM
Camaroholic's Avatar
D&D - http://www.ddperformance.com - would sell them. Considering mainshafts are $220, and gears are $150, they'll probably fall somewhere in between (tho I have not priced them).
What happened? (I gotta ask, just curious )
As for replacing them, I don't know if you could get away with pulling just the front cover or not... Normally I'd disassemble the entire tranny (full rebuild).
Old May 4, 2004 | 12:19 AM
onyxxtreme's Avatar
pilot bearing failed. The only thing left of it was the smaller inner sleeve, and the outer edges were all chewed up. So the input shaft has a couple grooves in it, one of em is pretty deep
I also drove it like that about 7k miles, and thought it was a hydraulic problem
all I can afford right now is the input shaft, and it looks like another $100 to have a pro replace it for me
Old May 4, 2004 | 10:37 AM
Bugsquawsher's Avatar
www.thegearbox.org also sells them
