Leaking T56
Old Sep 27, 2013 | 07:26 AM
99pewterZ71's Avatar
Default Leaking T56
I just got my GTO back on the road after a pretty catastrophic pressure plate blowing up and taking out the engine/trans/wiring/exhaust and the list goes on. I pieced together my T56 using most of what I could salvage from the original. Its leaking towards the tailshaft. I assumed it was the rear seal. I replaced it and the bushing with a Tick no-walk bushing (I reused my original tail shaft that appeared undamaged) It doesn’t seem to leak with the car sitting or with the front end jacked up in the air and only seems to leak when driving. It leaks all over the crossmember and exhaust making for a pretty embarrassing smoke cloud. I removed my shifter and put silicone around the base and still have the issue. It seems to be from the drivers side of the tail housing. Is it common for the reverse lockout or speed sensor to leak but only leak when driving? Thanks for the help.
