drain transmission?
Old Dec 3, 2013 | 11:09 AM
b00geyman's Avatar
Default drain transmission?
Do I have to drain the transmission of my t56 if I am only going to pull it out a few inches to get to the slave cylinder?
Old Dec 3, 2013 | 11:29 AM
redbird555's Avatar
no.....you will have to remove the driveshaft however then when you actually drop the trans a little bit, fluid will pour out of the tail. the solution is to either drain it or get a driveshaft plug and slip it into the tail before un bolting the trans
