which throw out bearing
Old Dec 14, 2013 | 06:23 PM
66duce's Avatar
Default which throw out bearing
I am swaping an ls6 into a 68 camaro and I will be using a 02 firebird t56. The ls6 had a good clutch which I am useing along with the vette master cylinder. Im thinking I should use the vette slave do you guys think this would be the correct way to go?
Old Dec 16, 2013 | 02:47 PM
SNLPerformance's Avatar
Yes, if using the C5 corvette master cylinder you will need to use the C5 corvette slave cylinder to match up in length.
Old Dec 16, 2013 | 04:57 PM
66duce's Avatar
Thanks
