T-10 direct replacement?
Old Dec 31, 2013 | 12:50 PM
Litl T&A's Avatar
Default T-10 direct replacement?
I know that the TH2004R bolts directly up to the stock TH350 tranny. Is there a manual tranny that bolts up to a stock T-10? If not what's the easiest swap from a stock T-10, looking for at least 5 speeds.
Thanks,
Litl T&A
Old Jan 2, 2014 | 07:47 AM
dgcustomz's Avatar
TKO 500/600. You can reuse your factory bellhousing, crossmember etc. Just need to swap to a 26 spline clutch disk.
Old Jan 3, 2014 | 08:13 AM
garys 68's Avatar
Richmond 5 or 6 speed. Reuse you clutch/flywheel, bell, z bar, crossmember, even the driveshaft. Also has the offset shifter in stock location.
