Tick Speed Bleeder
Old Feb 1, 2014 | 10:14 AM
EarlSS's Avatar
Default Tick Speed Bleeder
Tick Speed Bleeder..can it be installed when I install my Tick Master Cylinder without removing the slave? Also are there any tricks to getting the line out of the slave? I've pushed the white clip in with screw drivers but the line want budge!
Old Feb 1, 2014 | 10:27 AM
sleepinghawk's Avatar
Your tranny has to come out. I believe there is maybe a thread where 1 guy cut the floor beside the gas pedal to get to the line. I just did mine, with the tranny out. I got lucky with the 2 screw drivers to get the line out. Just take your time and play with it.
Old Feb 1, 2014 | 06:51 PM
EarlSS's Avatar
Thanks hawk, I've already got a hole beside my gas peddle to get to the bleeder valve on the slave. I thought maybe I could put the speed bleeder on from there.
Old Feb 1, 2014 | 07:02 PM
Silver98Formula79's Avatar
This photo should help you see how the speedbleeder is attached to the slave. It has a copper washer between the bleeder and slave.
Old Feb 2, 2014 | 12:14 AM
EarlSS's Avatar
Thanks Silver that does help. Even with the hole cut by the gas peddle it still looks like it'd be rough to get on without dropping the tranny. Also do you have any tips on getting the line off at the slave that comes from the master. Any tools or tips or just push the white ring in with screw drivers and play with the line until it comes off
Old Feb 2, 2014 | 07:28 AM
1BAD02WS6's Avatar
Clutch line disconnect tool. Or 2 flat head screwdrivers
