2000 T-56 issues
Old Feb 3, 2014 | 09:22 AM
voltage2009's Avatar
Default 2000 T-56 issues
Alright, so I was on the interstate and tried downshifting to 4th from 6th and it came out of gear just fine. I couldn't get it in any other gear so I coasted it off the interstate and slowed down enough to get in 2nd without the clutch. Drove it in 2nd for about a mile or so then the clutch started working again. Been working fine for the past couple days, then last night I had to fight to get in reverse. Once it went into reverse, it grinded a little. It functions properly but now sometimes makes a little squeaking noise from the front of the transmission. It's still hard to put into reverse, but it doesn't grind. Not sure what it is, need some suggestions. The car has 150k on it. Not sure when the last time the tranny fluid was changed, or any other tranny maintenance was done.
