bleeding and shim questions
1. where and when do you bleed it? i knew there's the mighty vac method and there's a bleeder valve on the slave, do you need to do both? can i get by with bleeding it when it's all installed from the slave?
2. my clutch (ram level 2) didn't come with any shims, are they necessary?
