Which master/slave to use?
Old Mar 1, 2014 | 08:24 PM
crazyc1123's Avatar
Default Which master/slave to use?
I'm currently in the process of converting my A4 car to an M6. I already have all the part including the clutch master and slave cylinders. I have a Spec 3+ clutch and flywheel setup but what I need to know is whether the factory 00-02 clutch master and slave will do the job without issues or do I really need to spend the extra for the after market parts? And if so what brands have you had the best experiences with? The other question I have is if someone has a link to a writeup on the wiring for the swap and locations/sizes for the holes that need to be drilled for the master. Thanks in advance for any advice. BTW all mods and current setup info are in my sig.
Old Mar 2, 2014 | 01:46 AM
_JB_'s Avatar
Tick masters and OEM slaves are good. Stay away from aftermarket slave cylinders.
Slave: http://www.tickperformance.com/gm-sl...-firebird-ls1/
Tick master: http://www.tickperformance.com/tick-...or-ls1-f-body/
Old Mar 3, 2014 | 07:48 AM
ponchjoe's Avatar
I too am having a few issues with the hydraulics, why are the GM slaves so much better? Where is the proof of this documented?
Thanks
Old Mar 3, 2014 | 11:20 AM
SNLPerformance's Avatar
If you have a properly functioning factory master/slave and a clutch that is fully disengaging then you should have no problems, hope that helps.
Old Mar 11, 2014 | 03:41 PM
crazyc1123's Avatar
Thanks for the info so far. Anyone with the installation writeup?
Old Mar 11, 2014 | 10:32 PM
chrysler kid's Avatar
Yeah its in the sticky at the top of the forum
FYI the gm and auto zone parts are the exact same down to the part number, stampings and everything.
Old Mar 12, 2014 | 02:50 AM
crazyc1123's Avatar
Ok cool thanks for the info
Old Mar 12, 2014 | 02:58 AM
luigiandme's Avatar
Stock and Stock. I would not use an aftermarket slave or master. Seen too many failures.
Old Mar 13, 2014 | 12:36 PM
crazyc1123's Avatar
Alright good because that's what I have waiting to go in. Thanks for the solid info.
