T56 Reverse Hard to engage
you can jack up the rear of the car (put on jack stands) start motor, put in gear, hold clutch pedal down....do the rear tires move?...they should not. If they do your clutch is not full disengaging which typically means hydraulics are failing
Thanks for the advice
OBTW, the album for my car is at https://ls1tech.com/forums/members/s...t56-31359.html
I also have the Wilwood with my McLeod twin, nice MC. I bench bleed mine first as installed in the car it was at an angle that did not allow the air to get out. YMMV, my application is a custom pedal in a car that never came with a stick
