clutch problems already!!!
Dave
My project is stalled because I am still waiting on my clutch/flywheel/slave from Monster, and I found a single needle bearing stuck to my oil drain plug.
. I wish I could get tick but just to pricey for me right now. tommorow I'm going to get a mc and install. I I used the mighty vac, but just to pull the old fluid out. I had installed the Tick speed bleeder which makes bleeding easy. I also did it old school with the Tick just to make sure the check valve worked. I used my wife to pump the clutch while I cracked the check valve, after the pedal was kept on the floor. I pumped atleast a pint of fluid to get it blead. Some did less and some did more. I followed the directions on here above the Manual, where the stickies are for How to bleed the clutch by Tick.
Read the Sticky on how to bleed and dont let your reservor go empty! There is alot of info thru search on here with answers to all questions.
https://ls1tech.com/forums/manual-tr...-properly.html
https://ls1tech.com/forums/manual-tr...d-threads.html
