Tr6060 help
You better figure out which one you're using. Production vs. aftermarket (T56 Magnum) has significant difference in driveline slip yoke or slip driveline) and shifter (tailhousing / case mount or remote) that work with it.
Shaft, gear linkage, clutch, flywheel will all be basic essentials anyway. If you can select and use an off the shelf trans, all the better.
