Need help...T56 rebuild
I've checked a few different threads but can't find what I am looking for. One thread here has it but the pictures wont come up.. shows a little pic of a frog. Anyways, is there a way the the synchro and blocker ring can come off without destroying the bearing on the end of the shaft or should I just press it all off and replace the bearing.
This is the thread I was using for reference:
https://ls1tech.com/forums/manual-tr...-write-up.html
Specifically:
From here the mainshaft must be take apart from both ends, a divider can be seen after removal of the 3rd gear.
Flip the mainshaft upside down on the stubby end, (right side of pic below)
-leave the bearing on unless you're replacing it.
(Starting left- large tapered bearing, 1st gear, 1/2 synchro, 2nd gear, 3rd gear, 3/4th synchro. Divider pointed out)
Remove:
3/4 synchro
-Pull 3/4 synchro sleeve off, either tap it off or use a puller
-Pull the synchro hub with a gear puller
Blocker ring
3rd Gear and caged needle bearing, (keep up with the bearings and where they go)
Spacer
All help is appreciated.
